21602 Discussions
MAX10/DE10-Lite board : SDRAM(64MB) problem downloading elf-file
Hi All,
I am using the DE10-Lite board with Quartus version 16.1. My application is running without any
problems on a DE1 board (8MB SDRAM), on a DE0-Nano board(16MB SDRAM) and on a BeMicro CV board
which is no longer available, so I decided to use the DE10-Lite board.
I have created a minimal configuration to narrow the problem. Enclosed, please find the
Qsys file. If necessary, I can provide the whole project as zip-file.
The program is running without any problems if only the onchip_memory is used, see 1).
The problem occurs if using the SDRAM only.
1) ok, using onchip_memory
Downloading 01000000 ( 0%)
Downloading 01010628 (95%)
Downloaded 66KB in 1.1s (60.0KB/s)
Verifying 01000000 ( 0%)
Verifying 01010628 (95%)
Verified OK
Starting processor at address 0x01000230
2) ERROR , using SDRAM
Downloading 04000000 ( 0%)
Downloading 040105B4 (95%)
Verifying 04000000 ( 0%)
Verify failed between address 0x4000000 and 0x400FA63
Leaving target processor paused
I already tried different possibilities to solve the problem and followed also the hints
and examples in the DE10-Lite_v.2.0.0_SystemCD but without success. I also tried to use
the Nios II (Classic) -E Processor with external PLL : same problem. I am using the
Single Uncompressed Image (3584Kbits UFM) Device option. At the moment, I am only able to
start the program from the onchip_memory, so I tried to get access to my data which is
based on a 48 MB union by changing via NiosII-BSP Editor the mapping from the .rwdata to
the SDRAM. Unfortunately I have no experience how to do that correctly and I did run in
a lot of other problems, probably my fault. It would be nice if someone can help me.
In general, however, it only makes sense if the SDRAM is working correctly and I
suspect that the problem is based in the RESET timing ?
Every reference is welcome. Many thanks in advance, Reinhard
In the meantime, I have solved the problem by myself.
It was related to the PINs DRAM_UDQM and DRAM_LDQM.
These pins have always been incorrectly created / designated (in version Quartus 16.1)
in a Qsys "Generate HDL ..." I changed it as follows:
# DRAM_LDQM,Unknown,PIN_V22,5,B5_N0,3.3-V LVTTL,,4ma,,,
# DRAM_UDQM,Unknown,PIN_J21,6,B6_N0,3.3-V LVTTL,,4ma,,,
DRAM_dqm[1],Unknown,PIN_V22,5,B5_N0,3.3-V LVTTL,,4ma,,,
DRAM_dqm[0],Unknown,PIN_J21,6,B6_N0,3.3-V LVTTL,,4ma,,,
