21611 Discussions
MAX10: Failed to download pof file.
I successfuly download sof file but when I try to download a pof file it fales.
I create the pof file fom a sof file Convert Programming Files->Programmer Object File(.pof)->Mode(Internal Configuration)->SOF Data(sof file)-> Generate.
I presume you are then using the Programmer to put the .pof in the CFM (configuration flash memory). How big is your .pof? Maybe it doesn't fit in the CFM.
I don't have any problems downloading pof file.
I followed this dokument:
http://www.terasic.com.tw/attachment/archive/956/max10neek_my_first_niosii.pdf
OMG. The problem was unconnected nConfig pin.
Hi John, I am experiencing similar problem on EQFP M50, which device are you using?
Best regards
