21615 Discussions
MAX10 Programmable IOE Delay
According to the datasheet, MAX10 have Programmable IOE Delay.
How can I use it?
Through which IP?
Through which Assignment?
Through SDC constraint?
See: "how do i set the ioe programmable delay values as listed in the device datasheet in the quartus ii software? (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd05052011_592.html)".
Cheers,
Alex
Thank you for the information.
This cover the static delay assignment case but I need dynamic (real time) update of the IOE delay.
I know that Cyclone and others uses ALTIOBUF IP but this is not available on MAX 10.
Any idea?
Dynamic delay chains are only available in certain device families, typically Cyclone V, Stratix V, Aria V and newer. It's not available in MAX 10.
Cheers,
Alex
