21602 Discussions
MAX10 and Flash Update module
I created Flash Update module with Qsys
onchip_flash_0 : component altera_onchip_flash generic map ( INIT_FILENAME => "", INIT_FILENAME_SIM => "", DEVICE_FAMILY => "MAX 10", PART_NAME => "10M50DAF484C7G", DEVICE_ID => "50", SECTOR1_START_ADDR => 0, SECTOR1_END_ADDR => 8191, SECTOR2_START_ADDR => 8192, SECTOR2_END_ADDR => 16383, SECTOR3_START_ADDR => 16384, SECTOR3_END_ADDR => 114687, SECTOR4_START_ADDR => 114688, SECTOR4_END_ADDR => 188415, SECTOR5_START_ADDR => 188416, SECTOR5_END_ADDR => 360447, MIN_VALID_ADDR => 0, MAX_VALID_ADDR => 360447, MIN_UFM_VALID_ADDR => 0, MAX_UFM_VALID_ADDR => 16383, SECTOR1_MAP => 1, SECTOR2_MAP => 2, SECTOR3_MAP => 3, SECTOR4_MAP => 4, SECTOR5_MAP => 5, ADDR_RANGE1_END_ADDR => 360447, ADDR_RANGE1_OFFSET => 2048, ADDR_RANGE2_OFFSET => 0, AVMM_DATA_ADDR_WIDTH => 19, AVMM_DATA_DATA_WIDTH => 32, AVMM_DATA_BURSTCOUNT_WIDTH => 4, SECTOR_READ_PROTECTION_MODE => 0, FLASH_SEQ_READ_DATA_COUNT => 4, FLASH_ADDR_ALIGNMENT_BITS => 2, FLASH_READ_CYCLE_MAX_INDEX => 5, FLASH_RESET_CYCLE_MAX_INDEX => 7, FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX => 36, FLASH_ERASE_TIMEOUT_CYCLE_MAX_INDEX => 10500000, FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX => 9150, PARALLEL_MODE => true, READ_AND_WRITE_MODE => true, WRAPPING_BURST_MODE => false, IS_DUAL_BOOT => "False", IS_ERAM_SKIP => "True", IS_COMPRESSED_IMAGE => "True" ) port map ( clock => clock, -- clk.clk reset_n => reset_n, -- nreset.reset_n avmm_data_addr => avmm_data_addr, -- data.address avmm_data_read => avmm_data_read, -- .read avmm_data_writedata => avmm_data_writedata, -- .writedata avmm_data_write => avmm_data_write, -- .write avmm_data_readdata => avmm_data_readdata, -- .readdata avmm_data_waitrequest => avmm_data_waitrequest, -- .waitrequest avmm_data_readdatavalid => avmm_data_readdatavalid, -- .readdatavalid avmm_data_burstcount => avmm_data_burstcount, -- .burstcount avmm_csr_addr => avmm_csr_addr, -- csr.address avmm_csr_read => avmm_csr_read, -- .read avmm_csr_writedata => avmm_csr_writedata, -- .writedata avmm_csr_write => avmm_csr_write, -- .write avmm_csr_readdata => avmm_csr_readdata -- .readdata );
In oreder to have two images - bootloader(CFM0) and main program(CFM1-CFM2) - I need Dual Compressed Images.
So I set - Assignments -> Device -> Devise and Pin Options -> Configuration -> Dual Compressed Images
And generics in Flash Update module I set
IS_DUAL_BOOT => "True", IS_ERAM_SKIP => "True", IS_COMPRESSED_IMAGE => "True"
When I compile I get an error
--- Quote Start ---
Error (169130): Configuration mode specified as Remote but remote update block is not found in design
--- Quote End ---
If I set Assignments -> Device -> Devise and Pin Options -> Configuration -> Single Compressed Image
And generics
It compiles without error.
And generics
I get an error
--- Quote Start ---
Error (14740): Configuration mode on atom "bootloader:U_BOOTLOADER|flash_update:U_FLASH_UPDATE|altera_onchip_flash : nchip_flash_0|altera_onchip_flash_block:altera_onchip_flash_block|ufm_block" does not match the project setting. Update and regenerate the Qsys system to match the project setting.
--- Quote End ---
How can I compile for Dual Compressed Images?
Have you set the correct parameter setting of Nios ll and on-chip ram?
Delete the incremental_db and db folder and recheck.
Refer the document for steps.
http://caxapa.ru/thumbs/592124/an730.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
--- Quote Start ---
Anand Raj Shankar
--- Quote End ---
I don't have NiosII in my project. It's QSYS generated core.
I go Tools->IP Catalog->Library->Basic Functions->On Chip Memory->Altera On-Chip Flash.https://alteraforum.com/forum/attachment.php?attachmentid=15108&stc=1
I deleted the incremental_db and db folder - it didn't help.
As it says, you need to have the RSU block in your design to use dual compressed images. See these online trainings:
https://www.altera.com/support/training/course/omaxrsu101.html
https://www.altera.com/support/training/course/omaxrsu102.html
--- Quote Start ---
--- Quote End ---
I see. Thank you.
Well...I created Altera On-Chip Flash module and Altera Dual Configuration module.
component flash_update is port ( clock : in std_logic := '0'; -- clk.clk avmm_csr_addr : in std_logic := '0'; -- csr.address avmm_csr_read : in std_logic := '0'; -- .read avmm_csr_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata avmm_csr_write : in std_logic := '0'; -- .write avmm_csr_readdata : out std_logic_vector(31 downto 0); -- .readdata avmm_data_addr : in std_logic_vector(18 downto 0) := (others => '0'); -- data.address avmm_data_read : in std_logic := '0'; -- .read avmm_data_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata avmm_data_write : in std_logic := '0'; -- .write avmm_data_readdata : out std_logic_vector(31 downto 0); -- .readdata avmm_data_waitrequest : out std_logic; -- .waitrequest avmm_data_readdatavalid : out std_logic; -- .readdatavalid avmm_data_burstcount : in std_logic_vector(3 downto 0) := (others => '0'); -- .burstcount reset_n : in std_logic := '0' -- nreset.reset_n ); end component; component altera_dual_config is port ( avmm_rcv_address : in std_logic_vector(2 downto 0) := (others => '0'); -- avalon.address avmm_rcv_read : in std_logic := '0'; -- .read avmm_rcv_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata avmm_rcv_write : in std_logic := '0'; -- .write avmm_rcv_readdata : out std_logic_vector(31 downto 0); -- .readdata clk : in std_logic := '0'; -- clk.clk nreset : in std_logic := '0' -- nreset.reset_n ); end component;
But I completely didn't understand how to connect between these two modules.
For a complete solution on dual configuration with reference design refer below link.
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an741.pdf
Anand Raj Shankar
Did you watch part 1 of the training? It goes through everything you need to do. You need a control mechanism, like Nios, to do this.
How do I map the module signals?
Especially avmm_rcv_address : in std_logic_vector(2 downto 0) - what is this address? why 3 lines wide? why there is no tutorial about Altera Dual Configuration module?
--- Quote Start ---
All documented here:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-10/ug_m10_config.pdf
--- Quote End ---
I have read this document. No explanation about the module. There is only a picture on the 2-16 page.
Look at the end of the document. The IP and its addressable locations are described.
--- Quote Start ---
--- Quote End ---
Sorry. I failed to understand what is it - Altera Dual Confguration IP Core Avalon-MM Address Map at the end of the document.
There are 3 columns in the table - Offset, R/W,Width. Offset of what? What all this obscure ciphers?
I have the following signals in this module
avmm_rcv_address[2..0]
avmm_rcv_read
avmm_rcv_writedata[31..0]
avmm_rcv_write
avmm_rcv_readdata[31..0]
How should I use it? Why should I seek an answer for a month? Where is a simple and clear explanation?
for example - for Altera On-Chip Flash IP there is a document explaining all ports and pins and diagrams for all operations - all clear.
what with this core? why should I have all this voodoo dances?
Address offset from the base address when you access the component.
If you're not familiar with using Intel FPGA IP or Platform Designer (formerly known as Qsys), I'd suggest searching for documentation and training on the Avalon interface and the use of Platform Designer.
Start with the Avalon spec:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/mnl_avalon_spec.pdf
--- Quote Start ---
--- Quote End ---
I've created the component with Qsys - there is no base address. Any way it makes no sense - offsets in the table don't correlate with actual ports I have in the module.
If you've looked at the training on RSU and the documentation, I'm not sure why you're still having an issue. The IP has an Avalon slave interface. You set a base address in Qsys (Platform Designer) so that a master component, such as Nios, can access and control it at a certain location in that master's address map. At the base address (offset 0), you access the control bits located in the first row of table 34 in the document I linked to. You adjust the address above the base address to access the other bits (default is increase address by 4 on the master to get to the next 32 bits (the second word) of the slave).
Again, if none of this makes sense, you should read and learn the Avalon spec and about basic addressing in Platform Designer.
