21608 Discussions
MAX10 mixed VCCIO for configuration pins
Hi
I am using a dual-supply MAX10 with banks 1a, 1b and 2 powered from 2.5 V and all remaining banks, including bank 8, from 3.3 V. I cannot find anything in the documentation suggesting that this is wrong however running the IO assignment analysis process from within Quartus produces the following warning:
Warning (169202): Inconsistent VCCIO across multiple banks of configuration pins. The configuration pins are contained in 2 banks in 'Internal Configuration' configuration scheme and there are 2 different VCCIOs.
I assume it does not like the fact that my JTAG header (which is connected to IO bank 1b) is running at 2.5 V whilst the configuration control/status pins, eg, nCONFIG, nSTATUS, etc, (which are all in IO bank 8) are all running at 3.3 V. Can you confirm that this arrangement is completely acceptable? I realise it's a warning rather than an error but I don't really see why it is even a warning.
Thanks in advance
Tim
Yes you are correct.
Warning can be removed by
Settings > Device > Device and Pin Options... > Configuration > Configuration device and un-checking the box "Force VCCIO to be compatible with configuration I/O voltage".
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Thank you for your reply, it's useful to know we do not have a problem with our hardware design.
Not a big problem but for your information, unchecking the "Force VCCIO to be compatible with configuration I/O voltage" option in the device settings does not seem to suppress the warning when building the FPGA. For reference, we are using Quartus Prime Version 17.0.0 Build 595 04/25/2017 SJ Lite Edition.
Tim
