21611 Discussions
MAX10DD devices seem to not support ADC Blocks ?!?
cjamcki
we have a design targeting 10M50DDF256I7G.  The device overview claims to support analog features as well as RSU, and some special flash access (not sure what that is but whatever).  However, in Qsys when you try to instantiate an ADC block (single or DUAL) IP core, it complains that the device doesn't support ADC.
Error: modular_adc_0: The selected device part number 10M50DDF256I7G does not support ADC
The pin planner for this device shows the pins having ADC as a pin option (maybe it's just a visual thing, but still).
If i target a 10M50AD device ("AD" vs. "DD"), it allows the ADC IP to be generated no problem.
So, why can't I use it in the DD device, or is not supported (even though the overview says so).
cjamcki
sorry, the line should read:
If i target a 10M50DA device ("DA" vs. "DD"), it allows the ADC IP to be generated no problem.
sorry about  that.
AqidAyman_Intel
I am really sorry for the experience you had. May I know if you okay to share your design to me either by private or if it is simple design and you don't mind you can share it here.
I need the .qar file to replicate the issue from my side for further escalation if needed.
Aqid
cjamcki
here is a basic project archive.   it has nothing in it except an "adc_bad" qsys file.  when you open it in platform designer, you'll see that it says the DD device is not supported, and you can't generate HDL due to that error.
if you re-target to a device with suffix DA, it doesn't complain.
thanks
AqidAyman_Intel
Thank you for the design file. What Quartus version that you are using?
cjamcki
Quartus Prime Version 22.1 std.0 build 915 10/25/2022 SC Lite Edition
Patches Installed: None
this is a windows version.  we've had similar issues on 20.1 on Linux
AqidAyman_Intel
Okay, thank you for the information and the design file. I will escalate this issue to the internal team. I will update you back once I got any feedback on this.
Pooh_Bear
Any update on this issue?
I am using the 10M40DD part and have the same problem. Fails to compile with Quartus version 23.1.std
Error (12252): Adc.modular_dual_adc_0: The selected device part number 10M40DDF256I7G does not support ADC
cjamcki
this really shouldn't be a difficult question to answer.  i see only two options:
1. the "DD" variant does not not support ADC (documentation error)
2. it does support it but there's a bug in Quartus/Platform Designer.
we were hoping to take advantage of the flash options of the "DD" version, but we intend to use the ADC as well.
we are getting close to ordering components for our program for prototype PCBs, so we really need to know the answer.  If it is, the first above, we will just switch to the "DA" flavor and forgo the flash benefits.
if it is the second choice above, we would need to know when a patch or variable setting or whatever would be available.  if it is too far in the future, we'd likely switch to the DA part as well.
AqidAyman_Intel
There is still investigation going on for this issue in Quartus.
Max 10 with "DD" variant should be the same as "DA" variant but with the additional "flash access control" feature. So, it should have the ADC feature.
This is likely to be the number 2 options.
I will definitely update back to you once I got the timeline to avoid this error.
Aqid
AqidAyman_Intel
May I confirm with you, for the Max 10 DA device, the design can be compiled successfully with the IP? If yes, can you please share with me the design or else, the IP parameters setting such as the sequencer, etc?
Aqid
FvM
you can make a very simple test, instantiate the add IP as top level entity. As expectable, failing of adc IP synthesis results in design generation failure.
Error (12252): Adc_bad.modular_adc_0: The selected device part number 10M50DDF256C8G does not support ADC
Error (12153): Can't elaborate top-level user hierarchy
(checked with Quartus Prime Std. 22.1)
cjamcki
you can just take what i sent previously, and change the target device to the DA variant rather than DD.  after doing so, and opening Platform Designer, you don't see the error in the window:
you can generate  HDL successfully (ignore the warning since this is a dummy design and not fully hooked up to anything useful):
as for the parameters of the ADC core, it seems to be rather inconsequential.  I've tried it with single channels, all channels, etc.  and it didn't matter.  the dummy design i previously sent has two of them enabled, as well as the sequencer.  you can open the block to check it out for yourself.
i'm uploading the SAME DESIGN, with only the target device changed to DA vs. DD.  You should be able to show someone else at your company what is going on, and maybe they can help you resolve this.
AqidAyman_Intel
Thank you for your information. The internal team have worked on this.
It is confirmed that Max10 "DD" variant should not getting the error.
The fix should be implemented in the future release of Quartus. Do you need patch to enable this in your current Quartus Prime version (22.1std) ?
Aqid
cjamcki
i think a patch for any version would help.  i'm using the 22.1std, but is the "LITE" version, not sure if it makes any difference for the patching.
thanks for the response!
AqidAyman_Intel
Unfortunately, I can only request the patch for Standard version regarding this issue.
Aqid
cjamcki
so you are going to make me buy a license for something that is broken ?  is that your way of getting me to pay for your errors ?
very bad business model.  you are going to be turning away customers.
cjamcki
what is the target release version to include this in a regular "LITE" version of quartus ... i.e., what date can we expect this fix to be deployed ?
AqidAyman_Intel
Sorry for the misunderstood. I have requested the patch for the version that you used (22.1std) and need your help to provide confirmation if it is really work on your side as the error seems to be fixed in the internal version.
I will contact you by private email to provide you with the file.
Aqid
cjamcki
ok, i''ll try it out when it's provided.
thanks
cjamcki
hello-
I successfully installed the patch provided, into my 'lite' version of 22.1:
i have been able to change my design back to the "DD" variant in Quartus, and then in Platform Designer it does not complain about the ADC blocks.  I was able to generate the IP from the Platform Designer, and then successfully place-and-route back in Quartus.
if you could provide a target release for the fix into the main Quartus release, it would be great.  This allows us to progress currently.
Thank you.
