21615 Discussions
MAXV - User Flash Memory Time Constraints
I try to time constrain my design using Altera block ALTUFM_SPI. I get many warnings from Quartus software like this one:
Warning (332009): The launch and latch times for the relationship between source clock: clk_dsp_dpi_p4 and destination clock: inst54|auto_generated|maxii_ufm_block1|osc are outside of the legal time range. The relationship difference is correct, however the launch time is set to 0.
I cannot succeed to get rid of those warnings.
Would someone have an example (more likely an SDC file example) on how to constrain ALTUFM_SPI?
Thank you in advance for your comments.
Fabe
I have still not been able to meet timing requirements with ALTUFM_SPI Block. I have defined an sdc file with four inputs and one output:
Inputs name: SCK - NCS - OSCENA - SI
Output name: SO
For some reason, I still get unconstrained paths even if it seems that all are constrained.
I still get warning messages and error messages like the one below:
Warning (332009): The launch and latch times for the relationship between source clock: osc1 and destination clock: osc5 are outside of the legal time range. The relationship difference is correct, however the launch time is set to 0.
Critical Warning (332148): Timing requirements not met
Someone would have some input regarding this?
Fabe
My SDC file is like below:
# SDC file
create_clock -name "osc1" -period 1000.0ns [get_ports {SCK}]
create_clock -name "osc2" -period 1000.0ns [get_ports {NCS}]
create_clock -name "osc3" -period 1000.0ns [get_registers {altufm_spi:inst|altufm_spi_m8s:auto_generated|dffe28}]
create_clock -name "osc4" -period 1000.0ns [get_registers {altufm_spi:inst|altufm_spi_m8s:auto_generated|dffe31}]
create_clock -name "osc5" -period 181.818ns [get_pins {inst|auto_generated|maxii_ufm_block1|osc}]
# Automatically constrain PLL and other generated clocks
derive_pll_clocks -create_base_clocks
# Block CPLD_EEPROM
# tsu/th constraints
# tco constraints
# tpd constraints
set_min_delay 10 -to [get_ports {SI}]
set_max_delay 80 -to [get_ports {SI}]
# set_min_delay 1 -to [get_ports {SCK}]
# set_max_delay 8 -to [get_ports {SCK}]
# set_min_delay 1 -to [get_ports {NCS}]
# set_max_delay 8 -to [get_ports {NCS}]
set_min_delay 10 -to [get_ports {OSCENA}]
set_max_delay 80 -to [get_ports {OSCENA}]
set_min_delay 10 -to [get_ports {SO}]
set_max_delay 80 -to [get_ports {SO}]
