21611 Discussions
MAXV maximum current per bank
What's the maximum current per bank in 5M570ZT144C?
I need to drive 56 leds with 5mA (280mA). Is it possible?
VDDIO = 3V3
Bruno Bernardi
There's no explicite specification in the datasheet, but I think you can refer to the MAX II related specification in AN286.
--- Quote Start ---
--- Quote End ---
Thanks for the reply.
AN286:"Although a single pin from a MAX 7000B device can sink up to 50 mA of DC current, each GNDIO group can concurrently sink up to 200 mA"
Does not exist similar specification for MAXV family?
--- Quote Start ---
--- Quote End ---
Didn't you find it? It's 170 mA if I remember right.
--- Quote Start ---
--- Quote End ---
The AN286 is not about the MAX V only MAX and MAX II.
170mA per pin (GND) or bank?
If 170mA per pin. Would be 850mA per bank?
according to AN286:
"For example, the EPM240 device has six GNDIO pads, which provide six I/O regions
that can sink up to 130 mΑ. If you need to sink 15 mA for the outputs, you can have
eight outputs per region. With the six regions of I/O between GNDIO pads, there are
48 possible outputs, each sinking 15 mA."
I think it's pretty clear if you review the MAX II data sheet and pin-out lists. I assume that MAX V has about the same current capability, but your requirements are distinctly below the discussed maximum ratings.
