21616 Discussions
Major mistakes in PCB Designing
"Hi, im new to PCB design. I want to avoid any major mistakes. Can I ask you guys
a few questions?:)
1. What was your biggest 3 mistakes designing and why?
2. most popular software that you use and why
3. Biggest 3 frustrations about PCB design?
4. Biggest 3 fears (maybe related to PCB Assembly)?"
Your guidelines will be more helpful to proceed further.:D
1. A. Not planning for proper clearance around components.
B. Getting footprints for connectors correct on the board (mirroe images, pin sequencing
1-2
3-4
5-6
7-8
compared to
1 5
2 6
3 7
4 8
compared to
1 8
2 7
3 6
4 5
C. Not properly addressing clock traces and interference.
2. no comment
3. same
4. A. Initial power up!
B. Accidental shorting of power / Gnd while testing
C. That little puff of blue / grey smoke.
It's easy to overlook the jtag or configuration circuits. While they do run fairly slowly, a clock is a clock. When you've got the JTAG TCK routed all over the place it's easy to run into reflection problems. And a double-clock is bad even at 10 MHz. So it's good to think about the design a bit, buffer if needed, or at least put down a series termination.
Gregor
Yes, not giving enough attention to JTAG and config is a common problem. Check out this thread that has some pointers on JTAG...
http://www.alteraforum.com/forum/showthread.php?t=687
Thanks for you support everyone..!! :D
S
