21615 Discussions
Matlab code to verilog
Hi there,
Is there a compiler which can convert Matlab code directly in to VHDL/verilog format so to implement the code directly in to FPGA? I am trying to write codes on MATLAB and would like to convert the code in to verilog format so to make my life easier.:)
thnks
Hi again,
I managed to make a Adaptive Noise Cancellation Algorithm on matlab. Can I transfer this code on to Simulink as a user define function block and then link my FPGA and transfer the code on to my FPGA????
No, it will not work.
To properly achieve what I was saying you will need to program your algorithm using exclusively simulink blocks, with no .m functions.
You basically need to rethink all your code and make it parallel.
