21611 Discussions
Matrix Multiplication Algorithm
Hello, Can anyone recommends me what is best way to multiply rectangular matrices that minimizes the combinational function?? I have written matrix multiplication code but total combinational functional are exceeding the maximum comb. functional of the device????
On searching some forums, I have found that one can do the multiplication using SRAM..I need some documentation on it?? How to use SRAM? and how it can be used for matrix multiplication...where can i found documentation on it??
Use bigger device is one solution
If you try implementing the code in NIOSII you could have a function for multiplication. You could also instantiate a LPM_MULT multiplier from the IP catlog to be the function that carries out the multiplication in your code. And for the SRAM thing you could try referring to the following link https://www.altera.com/solutions/technology/external-memory/sram.html. I am not sure how helpful the link would be. Thanks.
--- Quote Start ---
--- Quote End ---
Can you please tell me how to use megafunction??? some pdf document explanation???
the documentation for using the LPM_MULT and other arithmetic Ip cores can be found at
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_lpm_alt_mfug.pdf
