21603 Discussions
Max 10 Access in Stratix 10 DX
Manik
Hi Intel Members,
In Intel Stratix 10 DX board (https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=248&No=1258). I get to know that it has max 10 too.  I wish to know the possibilities and suggestions on the followings,
1. Is there any possibility to program and use max 10 alone without disturbing the Stratix 10 FPGA in the evaluation board?
2.If so is it possible to access some of the chipset present in the boards like EM2310, MAX6581, EM2410 etc thorough max 10 device without make use of Stratix 10 FPGA?
3. What is the significant of the use of max 10 device in that board ?
4. Should we need to set any configuration switches or jumpers to use max 10 alone.
Your suggestions and comments are highly appreciated.
Thank you
FvM
purpose of the MAX10 system controller is described in user manual and becomes more obvious if you study the dev board schematics. It can be accessed via JTAG header, but you rarely want to modify or replace MAX10 content because you'd loose essential functions of the dev board, e.g. Stratix 10 USB JTAG programmer and configuration flash.
I presume the MAX10 design isn't disclosed by Terasic as for other dev boards. If you feel that you are missing necessary information about MAX10 operation, e.g. regarding configuration controller features for remote update, contact Terasic support. They are really helpful.
FvM
Manik
Thanks for the insight. Let me check with terasic.
Fakhrul
Hi Manik,
I believe the response from our community member above has likely answered your question. However, if you require any additional information or have further inquiries on this topic, please don't hesitate to reach out. We are here to assist you with any concerns you may have.
Otherwise, this thread will be marked as inactive and will be transitioned to community support because there is no update received from you in a while.
Fakhrul
Fakhrul
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
