Max 10 FPGA
I am working on the MAX 10 FPGA board and I found that in the errata document it mentions:
if your existing design por scheme is configured to use either fast por delay or slow por delay
modes, you need to modify it to instant on mode.
How do i check that the POR scheme is Fast POR delay or slow POR delay or Instant ON mode in the FPGA? Can this POR scheme be changed using Quartus Prime? If yes, how?
The link to the errata document is given below
https://www.altera.com/en_us/pdfs/literature/es/es_max10.pdf
Such
Hi Such
Have a look to this document https://www.altera.com/en_us/pdfs/literature/an/an730.pdf (see page 22 and 23).
The power on reset scheme can be set in convert programming file window by setting the mode to internal configuration and open Options/Boot info window.
I hope this helps. With best regards
Chris
Chris,
Thank you i was able to change the POR scheme.
Such
