I am working on MAX V 5M2210ZF324C5 device for my current project. I require some of the pins to be pulled up as this wasnt taken care in schematics. Is this possible for the present device? Please help. Regards, Naga KiranLink Copied
Do a search for "Programmable Pull-Up Resistor" in "MAX V Device Handbook".
Yes. MAX V has programmable pull-ups. Enable/disable it under the 'Weak Pull-Up Resistor' column in the Pin Planner.
Note: --- Quote Start --- The programmable pull-up resistor is active during power-up, ISP, and if the device is unprogrammed. --- Quote End --- Cheers, Alex- Mark as New
