Programmable Devices
21602 Discussions
Max V static VCCINT current higher than expected
Has anyone else experienced higher than expected static current consumption on the VCCINT supply for Max V devices?
I am prototyping with the 5M240ZT100C5N part. The PowerPlay analyzer says I should have about 0.02mA of static VCCINT current. However, I am measuring more like 4.5mA. Dynamic current is as expected.
Nothing else is connected the 1.8V regulator. I am wondering if these devices are meeting their static power spec.
Tyler
Do you have floating inputs or inputs with pull-up connected to ground?
Hi FvM,
Thanks for the response.
No floating inputs or grounded pull-ups.
Also, this high static power consumption is for 1.8V Core power supply.
Tyler
--- Quote Start ---
--- Quote End ---
Yes. The pull-ups won't matter. Floating inputs could cause oscillations that also effect the idle current.
You should ask Altera support.
