Programmable Devices
21608 Discussions
Max VII device file
I am completely new to Altera and Quartus II. I am using Quartus II 64-bit 13.1.0 under Ubuntu Linux.
I have a programmable NIM module with an Altera MAX chip to program to be able to make some
2-fold or 3-fold time coincidence from an input of 8 channels. Does anybody know a similar usecase
and/or some related example project files?
While watching tutorials I learned I need to specify the device I have (Altera MAX EPM7128SLC84-10N)
under Assignments->Device. However, I don't see Max VII device family in the drop down list.
When at the common Altera download page I did not find support device files (qdz) for device family Max VII.
Could you help to find out how can I install qdz device files for my chip?
Thanks a lot for any help.
Kind regards,
Balint
Its not a max VII, its a max 7000, which is very old and IIRC, support was dropped in quartus 10.0.
--- Quote Start ---
--- Quote End ---
Thanks a lot for your answer! So, I may need to use some older version to work with it, < 10.0 ? I hope it works out...
Cheers,
Balint
