21597 Discussions
Max10 Single supply internal voltage regulator
Hi
MAX[SUP]®[/SUP] 10 single-supply devices only need either a 3.0- or 3.3-V external power supply. The external power supply serves as an input to the MAX[SUP]®[/SUP] 10 device VCC_ONE and VCCA power pins. This external power supply is then regulated by an internal voltage regulator in the MAX[SUP]®[/SUP] 10 single-supply device to 1.2 V. The 1.2-V voltage level is required by core logic operation.
My question is: What type of voltage regulator is used ? Linear regulator ? Switching regulator?
Almost certainly linear.
Mybe you may follow the Altera example on your application. The avaluation kit for 10M08 uses this switching regulator:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ds/ep5388qi_02377.pdf
Let me clarify my previous response. The external power supply (3.0 or 3.3V) may be switching or linear, your choice. The internal voltage regulator is almost certainly linear.
Thank you very much for yours answers :)
