21615 Discussions
Memory Block Allocations
Hi!
I was wondering if there was a quick way to see how many of the device's memory blocks are being used. I can see the number of bits in the Compilation Report, but I'd like to see how many blocks are being used.
Thanks!
--- Quote Start ---
Hi!
Thanks!
--- Quote End ---
an easy way to get this info is to customize the columns in the Project Navigator window.
Put the cursor on "Entity" , right mouse click and a window open, where you can choose what you like to see.
Kind regards
GPK
If you go to the fitter report, click on the resource section and it should tell you the information you want to know.
