Hi everyone,
All of our projects are under Quartus II 9.1, and we were thinking of upgrading it to the 13.1 version. Do you know if there is any compatibility problem if we migrate our projects from 9.1 to 13.1 ?連結已複製
8 回應
Yes the migration issues really depend on the IP you are using.
If you are using SOPC builder and NIOS the difficulty is higher than if you are just using memories and PLL's but you may need to regenerate code IP blocks in either case. I have taken a design from Quartus 6 to 13.1 through the various versions in between. The primary issue I had was with the FFT core changing it's IO interface at one point, but most designs will compile with little issues. Pete
