- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
could someone clear this up for me: from SIII configuration manual: " On all Stratix III devices in the chain, nCE should be driven low by connecting it to ground, pulling it low via a resistor, or driving it by some control circuitry. For devices that are also in multi-device FPP, AS, or PS configuration chains, the nCE pins should be connected to GND during JTAG configuration or JTAG configured in the same order as the configuration chain. " What does the last bit mean i.e. JTAG configured in the same order as the chain? Is this simply a case of ordering the devices in the programming utility window so that they match the physical order? Does this mean I can perform JTAG configuration as well has doing multi-device FPP where the CE pins are daisy-chained? Or, must I force the CE pins to ground when doing JTAG? Thanks and regards, Dave.Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The Configuration Handbook mentions this point more than once: nCE must be held low during JTAG configuration. You have two options to achieve this: 1. Connect the pin to ground. 2, If it's connected to preceeding devices nCEO in multi device chain (may be AS, AP, PS or PP), this device must be configured before, cause nCEO will go low only after succesful configuration. configured in the same order means the actual sequence in time. If you want to program all devices in a single action, then this would be identical to the order in JTAG chain which is also the order in the programming window.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thanks, but is the correct order that which is autodetected? (Because you can manually re-order following auto-detection).
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The JTAG chain order may be different from the nCE chain order, autodetect is only related to JTAG.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
OK, I see. Thanks very much.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
