21612 Discussions
Modelsim can not find "altsyncram"
Dear all, I am using Modelsim for simulation,
Modelsim says" Instantiation of 'altsyncram' failed, the design unit was not found", even though 'altsyncram' is in "Altera_mf" library, listed on the "library Panel".
What should I do?
Thank you very much!
Other errors: "Instantiation of 'oper_selector' failed, the design unit was not found", there is a .ocp file in altmemphy-library, what does it do? should it be included in Modelsim?
--- Quote Start ---
What should I do?
--- Quote End ---
did you include the library in your simulation ? Seeing the library in the library panel does not mean that they are included.
Kind regards
GPK
Could you tell me how to include? how to check?
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
# get a proper makefile
exec vmake work > Makefile
# Run it to compile what needs to be compiled
make
# Start simulation
vsim -L altera_mf_ver -L lpm_ver -L cycloneiii_ver -L cycloneii_ver work.dut_tb
After those you can simply do:
make; restart -f; run -all
--- Quote Start ---
What should I do?
--- Quote End ---
Hello binpersonal,
I also met this problem. Have you fixed it? and How do you solve this problem?
thanks!
I am using modelsim in a Ubuntu 10.04 LTS Lucid Lynx.
Also i am compiling verilog files (and simulating them) in command line.
I fixed it using the following command (after all necessary compilations):
vsim -c -t 1ns -quiet -L $(MEGAFUNCTIONS) work.RomTests -do "run 1000000 1ns; quit"
where MEGAFUNCTIONS should be your path to "altera_mf", which includes all megafunctions from altera:
[installation path]/altera10.0/modelsim_ae/altera/verilog/altera_mf
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
To resolve this problem you need to specify the right libraries when you are trying to simulate in ModelSim.
The breif steps are
1. Compile the testbench code <testbench.v> , it gets included in your 'work' library.
2. Select 'Simulate' -> 'Start Simulation' from the menu.
3. Click on the 'Libraries' tab in the new popup window and press 'Add' to include the 'altera_mf_ver' library (if you are working with Verilog) to the 'Search Libraries First (-Lf)'
4. Finally, select your testbench from the 'Design' tab.
The design should simulate now.
I have included some screenshots for assistance.
migry_tech
Many thanks for the explanation listed as the 4 steps above. I am new to Modelsim-Altera and this solved the problem. I am now simulating my memory successfully, however I got caught out because I registered both the address and q without realising. Simulation and google(!) helped me find the bug.
--migry
