21611 Discussions
Modelsim compiling error:(vcom-11) Could not find work.stratixiv_hssi_components
hey,everyone!
I am doing simulation with modelsim.When compiling the libraries before runing the do file, i am confused of the error below:# ** Error: (vcom-11) Could not find work.stratixiv_hssi_components.# ** Error: ./altera/stratixiv_hssi_atoms.vhd(112): (vcom-1195) Cannot find expanded name "work.stratixiv_hssi_components".# ** Error: ./altera/stratixiv_hssi_atoms.vhd(112): Unknown expanded name.# ** Error: ./altera/stratixiv_hssi_atoms.vhd(114): VHDL Compiler exiting# ** Error: D:/EDA_Tools/modeltech_6.5e/win32/vcom failed.
But in fact i have do the tcl script of compiling stratixiv_hssi_components.vhd.Could anybody knows why?Thank you very much!
Here is my tcl script:
if ![file isdirectory verilog_libs] {
file mkdir vhdl_libs
set vhdl_dir "./altera"
vlib vhdl_libs/altera_V
vmap altera ./vhdl_libs/altera_V
vcom -93 -work altera $vhdl_dir/altera_primitives_components.vhd
vcom -93 -work altera $vhdl_dir/altera_primitives.vhd
vlib vhdl_libs/lpm_V
vmap lpm ./vhdl_libs/lpm_V
vcom -93 -work lpm $vhdl_dir/220pack.vhd
vcom -93 -work lpm $vhdl_dir/220model.vhd
vlib vhdl_libs/sgate_V
vmap sgate ./vhdl_libs/sgate_V
vcom -93 -work sgate $vhdl_dir/sgate_pack.vhd
vcom -93 -work sgate $vhdl_dir/sgate.vhd
vlib vhdl_libs/altera_mf_V
vmap altera_mf ./vhdl_libs/altera_mf_V
vcom -93 -work altera_mf $vhdl_dir/altera_mf_components.vhd
vcom -93 -work altera_mf $vhdl_dir/altera_mf.vhd
vlib vhdl_libs/stratixiv_V
vmap stratixiv ./vhdl_libs/stratixiv_V
vcom -93 -work stratixiv $vhdl_dir/stratixiv_atoms.vhd
vcom -93 -work stratixiv $vhdl_dir/stratixiv_hssi_atoms.vhd
vlib vhdl_libs/stratixiv_components_V
vmap stratixiv_components ./vhdl_libs/stratixiv_components_V
vcom -93 -work stratixiv_components $vhdl_dir/stratixiv_components.vhd
vcom -93 -work stratixiv_components $vhdl_dir/stratixiv_hssi_components.vhd
The error message indicates that the HDL code has a VHDL statement like
use work.stratixiv_hssi_components.all;
whereas you have compiled it into the VHDL library stratixiv.
Either compile it into the "work" library, or just edit the source to
library stratixiv;
use stratixiv.stratixiv_hssi_components.all;
I've had to edit Altera's source before due to "work" being used in some files, and "stratixiv" being used in others.
Cheers,
Dave
chami
I had the same error. I modified my .do file to compile the files into work:
vlib work
vmap work work
vcom -93 -quiet -work work \
$env(QUARTUS_ROOTDIR)/eda/sim_lib/stratixiv_hssi_components.vhd \
$env(QUARTUS_ROOTDIR)/eda/sim_lib/stratixiv_hssi_atoms.vhd
and then I located the vhdl file where the error is occurring
and changed
library stratixiv_hssi;
use stratixiv_hssi.stratixiv_hssi_components.all;
to
library work;
this is what I did!
