21611 Discussions
Modelsim stuck in clock_div loop
nome
Hello
I am using Arria FPGA configuration from Max II CPLD with m29ew parallel flash x8 mode I am not using PFL megacore IP.
 I am using configure fpga by using  config_controller.vhd  from intel official
please find in attachments
whenever I simulate these codes in Altera modelsim it will stuck in clock_div loop but when i press restart button in modelsim it will working good
 kindly help us
Nome
ShengN_Intel
Hi Nome,
Based on the code provided, I had commented out those two modules config_state_machine and config_control_signal instantiations since not provided.
I noticed you have commented out all the RESET_n port connection and instantiated signal RESET_n to '0' with signal RESET_n : std_logic := '0'; So signal RESET_n will be always '0'. Also, signal MAX_EN is always '0' as well. That's why it will stuck in clock_div loop and keep resetting like below pic.
If instantiated signal RESET_n to '1' with signal RESET_n : std_logic := '1'; It will no more stuck in clock_div loop like below pic.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
ShengN_Intel
Let me know if you have any further update or concern?
Sheng
