Is there a setting in Modelsim waveform viewer by which we can disable/enable display of glitches?? I know there are glitches in my design and it is acceptable. I just do not want see it in the waveform. Thanks VinayLink Copied
modelsim only shows what actually happens. it cannot determine what is a glitch and what is not.
you can "register" the outputs in question in your test bench
