21611 Discussions
Multi IO voltage JTAG
My circuit is composed 4 Stratix4s per chain.
And each FPGA has multiple IO voltage. (see attachment picture)
Vccio of each FPGA's bank1A is connected to 2.5V.
So we connected pull-up to 2.5V.
But in my circuit there are no buffer or voltage translator.
i wonder my circuit conceptually is good for jtag operation without level translator.
JS Lee
Your JTAG chain is apparently all-2.5V. Why should it need a level translator?
Extensive JTAG chains might have problems with crosstalk of fast on-board to JTAG signals, particularly TCK. In this case, buffers can be helpful sometimes.
Hi FvM,
Thank you for your reply.
It's lucky.
Anyway did you mean, even if other IO bank is connected different VCCIO, it is nothing to JTAG interface right ?
Boundary cells are supplied from each VCCIO, so different IO bank might cause the error when signal shift to next cell.
That's my concern.
I want to clarify my concept.
Thank you ~
This issue is solved. The circuit has no problme. The problem was "Damaged FPGA". Thanks a lot.
