21615 Discussions
Multiprocessor & superloop simple socket
hi,
This is my design (http://img193.imageshack.us/img193/8141/sopc.jpg), i want to to use cpu_tse to handle ethernet without linux
So, i looked to "Building 3c120 Superloop Simple Socket Server Plus"
I connect the cpu_tse to the flash...
I need to know if i have to make some changes in my design to use SSS
Well it's obviously a little difficult to quickly look at the picture and see everything. Basically all you need to run SSS is:
1 - CPU
2 - Boot memory (you're going to use the flash)
3 - Program memory (looks like you're going to use the DDR memory)
4 - MAC (you're using the TSE MAC which means you need the SGDMA controllers and onchip memory for descriptor storage).
That's it. Nothing else needed. Well technically the SSS example uses a PIO to drive the LED but that's easy to remove.
Jake
thank you jake,
I should change some script too...
What script are you referring to?
Jake
create-this-bsp script, create-this-app
