I am using the the "My First FPGA" Tutorial pdf to create a program for my board.
This tutorial does not have the Arria II GX board reference so i used the Arria GX information up untill the pin assignments where i tried to assigns what i believed to be the correct assignment. Is there a tutorial like this for the Arria II GX FPGA board? or could anyone give me the PIN assignments for the clock, user LED, User puch buttons and any other information that might need to be tailored to the Arria II GX board. I really need help, this board is not being very nice to me :cry: The tutorial is the tt_my_first_FPGA pdf search it cause it would let me put the link to it because i have less then 5 post. (dumb) thank youLink Copied
If you have the a2gx devkit, you can use the existing bts deisgns, or bup design to start with.
Both are in the devkit folder. I think it should be in example/board_test_system/ bts_config is one of the easy one, which has LED or pb or some others.- Mark as New
thank you. I was able to input the pin assignments from the board test system. I was just so caught up that it didnt cross my ind to do that.
