Programmable Devices
20725 Discussions
NEED HELP FOR DE0's UART
Hi everyone,
i need to image processing with FPGA.I have Altera DE0(ACEDEMIC).i should take image from pc and send to SRAM.Can i do it with USB(JTAG) or i need to use RS232 cable?
TY FOR ANSWERS!
if you want to use JTAG you can use the JTAG to Avalon Master Bridge in Qsys or the JTAG UART IP. I recommend you to read the user guides of those IPs and evaluated which is is better option for your design.
Cheers,
fade
ty for answer!
actually i want to send a image from pc to fpga(de0 acedemic),i have usb blaster so can i do it with usb blaster? and if answer yes which way should i use?
