21602 Discussions
NIOS BSP custom Instruction Flags
I am using NIOS IDE V 8.1 with SOPC and currently I am using the following source: (http://www.alterawiki.com/wiki/custom_floating_point_unit ) for setting the custom instruction for setting up the flags in the compiler.
I need to know how to set up the compiler flags for NIOS BSP V13 with Qsys.
I really appreciate any help.
Thank you,
Allen
I got the same problem, have you find a solution to compile the code with real custum instruction ?
regards
