21611 Discussions
NIOS2 reset under high temperature
Hi all,
I am currently working with a Cyclone III and I have a problem with my NIOSII when the temperature reach around 83 °.
My NIOSII code is executed in a DDR memory and when my CycloneIII reaches this temperature, my NIOSII is reseting
I have few ideas:
* Noise on the core voltage with this temperature.
* Access time in the DDR too long (so the NIOSII is executing bads intructions).
* Bad constraints in timequest.
How can i identify the source of this problem ?
Have you some ideas to fix it ?
are you passing timing? what is your clock rates for nios and ram?
I've exactly the same problem but it's not nios2 reset but a FPGA reconfiguration.
Someone can help me ?
DDR at 166.67 MHz (same problem with DDR at 133.33 MHz)
Nios2 at 100MHz
