21582 Discussions
Need Advice - First time PCIe device development + QSYS
I appreciate any advice/reading materials you can suggest to clarify my issues.
I am developing a StratixV-based PCIe card. The card was developed by another company, but they have provided all of the specs for the external DDR interfaces and PCIe interfaces. The card has a PCIe 3.0 compatible interface and two external DDR3 banks.
I am trying to use QSYS to instantiate the PCIe hard IP core for Stratix V, and have some questions.
q1:
For the PCIe core instance I am using the Avalon-MM interface. I configured two BARs, 0 and 1, as 32-bit non-prefetchable memory. BAR0 I am reserving for the control and status register (CSR) hookups. BAR1 I am using for the scatter-gather DMA controller descriptor table memory. Is this a good design choice?
Is there a typical design pattern for choosing how to assign each BAR?
q2:
I originally started my design using the Avalon-ST Stratix V HIP PCIe core, but ran into some issues with the Stream-Memory SGDMA controller IP. The symbol size for the PCIe output was 128-bits, while the SGDMA was a single byte. I am assuming in streaming mode the ST interface is dumping the entire TLP packet on the streaming interface. In that case, I was thinking of doing a DC FIFO -> packet to byte IP -> SGDMA controller. Was I thinking along the correct lines?
q3:
I am actually thinking this is more of a bug with QSYS 13.0sp1. I was generated my synthesis files as VHDL, and during compilation there was an error from the altera_pcie_sv_hip_avmm.vhd file that was complaining about the direction of tlbfm_out. The VHDL component declaration used an output, while the underlying verilog entity used that signal as an input. I am assuming this is either a bug, or I some how connected a signal incorrectly.
Thank you for your help.
Sorry for the double post. One more question:
For the scatter-gather DMA controller in QSYS, it appears the address bus for the m_read/m_write ports are limited to 32-bits, although in the documentation it says it is capable of 64-bit addressing in the descriptors.
I would like to map the DMA controller to 2 8GB memories and the PCIe core TXS port, but I am running into an issue with the address decoding (since the decoding requires > 32 bits). What am I doing wrong? Do I need to add Avalon-MM multiplexer and select between banks ?
Thank you.
I wrote up my impressions of the Qsys PCIe interface in this thread:
http://www.alteraforum.com/forum/showthread.php?t=35678
The Qsys component is not very useful. A 32-bit Avalon-MM target is used to generate PCIe transactions. A 64-bit PCIe address is constructed using the 32-bit Avalon-MM address as an offset, and the 32-bit MSBs are filled in by a register setting. I feel this is a very limited solution, given that host memory pages could be located anywhere in 64-bit PCIe space.
If you want a "real" PCIe initiator implementation in the FPGA, you will either need to implement your own Qsys interface, or look around and see if there is a third-party IP core that supports what you want. If you do look at third-party IP, make sure they have a decent PCIe BFM so that you can create testbenches.
This is just my impression ... others can comment if they've had a better experience with Altera's PCIe offerings.
Cheers,
Dave
Hi Evgeni,
Just to confirm my understanding, since you've been using this core. In your address translation settings, you've got a 24-bit address (16MB ), so you can DMA from your Qsys 32-bit address space to a 16MB window in PCIe space. The MSBs of the 64-bit address are set by another register in the Qsys PCIe component.
How do you deal with the "real world" of host memory addresses that have arbitrary 64-bit addresses?
In the University Program PCIe examples I looked at, they "cheated" by having a 2GB window, and then using a memory allocation scheme on the host PC, where memory pages were restricted to lie below 2GB on the host (or at least within a fixed 2GB window).
A "real" PCIe master/initiator scatter-gather DMA controller should be able to generate an arbitrary 64-bit address for each transaction in the scatter-gather DMA list. You can create such an interface with Altera's IP cores, however, you have to use the lower-level streaming PCIe core, rather than the Qsys core.
Cheers,
Dave
Hi Dave,
Just to clarify that we're talking about Endpoint, not PCIe Root device.
In this particular design PCIe is Avalon-MM master. 24-bit address is calculated automatically by Qsys system builder; it probably looks at the highest address of all connected Avalon-MM slaves.
I didn't have a chance to deal with the case you described. The "worst case" design is 64-bit PCIe Endpoint connected to an embedded processor (PCIe Root) + DMA. So we can control memory allocation scheme on that processor.
Evgeni
Hi Evgeni,
--- Quote Start ---
--- Quote End ---
Yes, the use-case I was considering was an "intelligent" PCIe peripheral device that needs to perform high-performance transactions between itself and a host (root complex). Since high-performance is required, the peripheral device needs to support being a bus master/initiator, and perform burst transactions over the PCIe bus. Typically such an interface is implemented using a DMA controller that has one address in whatever is native for the peripheral logic, eg., 32-bit Avalon-MM addresses, another address for the 64-bit PCIe bus, and a direction bit indicating whether the burst is to or from the PCIe bus.
--- Quote Start ---
--- Quote End ---
Sorry, this comment is not clear. "PCIe is Avalon-MM master" implies that the peripheral board is a PCIe target, where the PCIe transactions are converted by the Qsys PCIe bridge into Avalon-MM transactions. In this case the host accesses the board via the BAR registers, and the 24-bit address translation window discussed above has nothing to do with the transaction.
The 24-bit address above configures the width of the TXS Avalon-MM slave/PCIe master. Avalon-MM accesses to that 16MB range get translated into 64-bit PCIe accesses, where the LSB 24-bits are the same as the Avalon-MM address bits, but the (64-24)= 40-bits MSBs are determined by a pseudo-static register setting in the Qsys PCIe bridge control registers. The 40-bit MSBs are pseudo-static in that an SGDMA controller on the Avalon-MM bus cannot easily change the 64-bit PCIe addresses (the scatter-gather list would require 'extra' entries to write a new 40-bit address to change the PCIe MSBs).
--- Quote Start ---
--- Quote End ---
In what way is this a worst-case? (just so that I understand)
Cheers,
Dave
Hi Dave,
There is a PCIe core serves as an Avalon-MM master. User specifies, for example, 64Mbyte BAR, or 26bit. But I found that Qsys recalculates this to lower value, based on the actual addresses of connected Avalon slaves, for example 24 bit
By "worst case" I meant the most complex PCIe configuration of designs I work with.
Evgeni
Hi Evgeni,
--- Quote Start ---
--- Quote End ---
Ok, so your application is to use the Qsys PCIe core as a target device. My "complaints" relate to its short-comings as a PCIe master :)
--- Quote Start ---
--- Quote End ---
That's clearer, thanks!
Cheers,
Dave
Hi Evgeni,
I saw your jpgs, however, I have questions, why don't you use DMA? and, how to set its TLP for 64-bit OS host PC (Linux)? I'd like to do development based on Reference Design under QSys, however, modifying its TLP is still a mystery for me.
I didn't need to use DMA - my designs just do a lot of register accesses.
Evgeni
