21615 Discussions
Nios DDR3 Test Example Project TimeQuest Negative Setup Slack
Hello everyone,
I've been trying to understand the workings of the timing analyser recently. I need to implement an SDRAM Controller with Uniphy in my design.
So I opened up an example project called "SoCKit_DDR3_Nios_Test. I noticed it is very similar to mine, it has a nios processor, onchip mem, clock, and so on.
After compiling and constraining the I received a setup violation error. I don't know what is wrong with my constraint. I doubt I need to use set_input_delay or set_output_delay, since the sdc file doesn't even have clock groupings, which I added later on to try to repair the setup slack. The clock groupings managed to correct the negative slack on the generated clock "u0|pll_qsys|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk"
This is my sdc file.
create_clock -period 20 create_clock -period 20 create_clock -period 20 create_clock -period 20 derive_pll_clocks derive_clock_uncertainty set_clock_groups -asynchronous -group {OSC_50_B3B OSC_50_B4A OSC_50_B5B OSC_50_B8A } -group { u0|pll_qsys|altera_pll_i|general.gpll~FRACTIONAL_PLL|vcoph u0|pll_qsys|altera_pll_i|general.gpll~PLL_OUTPUT_COUNTER|divclk } -group { u0|mem_if_ddr3_emif_fpga|DDR3_Qsys_mem_if_ddr3_emif_fpga_p0_sampling_clock } -group { u0|mem_if_ddr3_emif_fpga|pll0|pll_addr_cmd_clk u0|mem_if_ddr3_emif_fpga|pll0|pll_avl_clk u0|mem_if_ddr3_emif_fpga|pll0|pll_dq_write_clk u0|mem_if_ddr3_emif_fpga|pll0|pll_write_clk } -group { u0|mem_if_ddr3_emif_fpga|pll0|pll_afi_clk } -group { DDR3_CK_n DDR3_CK_p DDR3_DQS_n_OUT DDR3_DQS_n_OUT DDR3_DQS_n_OUT DDR3_DQS_n_OUT DDR3_DQS_p_IN DDR3_DQS_p_OUT DDR3_DQS_p_IN DDR3_DQS_p_OUT DDR3_DQS_p_IN DDR3_DQS_p_OUT DDR3_DQS_p_IN DDR3_DQS_p_OUT }
I can't really wrap my head around the behind-the-scene workings of Altera. Can someone please explain me?
I look forward to any replies :)
BTW I'm using Quartus 14.1
I can't read your screenshot to see what paths are failing, but the IP should have generated a .sdc file for you.
Oh I'm sorry about the screenshot
Please try this link
https://imgur.com/a/yr9ldwm (https://imgur.com/a/yr9ldwm
The sdc file from the previous post was the generated sdc file. I just added the clock groups to see if that solves the failure.
I added the source project folder to my attachments. This is in its original form.
I would appreciate any help.
