Hellow,
So, my problem is as follows. I get this warning : taking address of expression of type 'void' [enabled by default] about 9 times, and it points to the alt_load.c file does anyone know how to fix it? it does not interrupt my compiling, and the code works, but still, maybe later i will have problems with it. Please help if you can, and thanks.Link Copied
I am also getting this warning when I transferred my project to Q13.1. This warning is not present in 12.0 Quartus and NIOS SDK. Enabling all options @ BSP settings --> Advanced --> HAL --> linker (tick all the 5 boxes), seem to have cleared this warning. I am not sure how this makes a difference in Q13.1!. In 12.0 only 2 nd and 4th options were set by default. Hope this helps.- Mark as New
--- Quote Start --- Hellow, So, my problem is as follows. I get this warning : taking address of expression of type 'void' [enabled by default] about 9 times, and it points to the alt_load.c file does anyone know how to fix it? it does not interrupt my compiling, and the code works, but still, maybe later i will have problems with it. Please help if you can, and thanks. --- Quote End --- I have the same warnings when transfer a project in Quartus 13 to 13.1. Don't know why.
