21598 Discussions
Nios II Program Counter
Is there anyway to access the Nios program counter from the hardware (instead of using instruction like nextpc..) ? :confused:
Nice question, sorry I can not help you but I can suggest you to post your question to the Nios Forum.
I already posted the question there 2 months ago but seems no reply so far...:(
Why do you need it? What will you do with it?
If you say accessing it? Is it access in software, or in hardware?
Stefaan
You can only read it via the nextpc instruction.
From the NIOS II instruction set reference:
nextpc get address of following instruction Operation: rC ← PC + 4 Assembler Syntax: nextpc rC Example: nextpc r6 Description: Stores the address of the next instruction to register rC. Usage: A relocatable code fragment can use nextpc to calculate the address of its data segment. nextpc is the only way to access the PC directly. Exceptions: None Instruction Type: R Instruction Fields: C = Register index of operand rC
Obviously you can modify the program counter via jump and branch commands.
Jake
