Nios ii
Help Please!
I' m new in NIOS II and I try to follow this tutorial in youtube" https://www.youtube.com/watch?v=w82xFo1RNmo
but this error appear :
collect2.exe: error: ld returned 1 exit statusmake: *** [led.elf] Error 1
My board is FPGA CYCLONE V : 5CSEMA5F31
There is an attachement for more details!
THANKS
1. Select latera on-chip memory size in QSYS.
Don't forget to re-generate the code in QSYS and re-compile in Quartus.
or
2. Select the "small hello world" template to create a new project or from BSP Editor enable the checkbox enable_small_c_library.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Hello ,
yeah I change the program because aia need a timer application .
so I try to implement counter but it still the same problem
I change my memory size but it gives me an error so I kept 4096
I found the bsp editor empty in eclipse
there are some attechment for more details.
Thank you for help.
Imen.
Eclipse may not have loaded the .sopcinfo file correctly because of which you are not able to see the options from BSP Editor.
Refer the attached for steps.
If you face the same problem deleted the incremental_db, db folder and software folder. Compile qsys design and create new eclipse project.
Anand Raj Shankar
yes I did all those instruction but it failed
keep give ;e this error
make: *** [Keep_working.elf] Error 1
I dont knoz how can I resolve to go on My project
Thank you for your help
best Regards
Which version of Quartus and Eclipse are you using?
And elaborate the steps you have followed for creating a project. (because video link you have shared does not give complete steps)
Anand Raj Shankar
thank u.
It work with me
BestRegards
Imen.
I have an other question please
I try to run the counterbinary (library)
I build the qsys and my code eclipse every thing is good
I saw result in console of eclipse but nothing work in my FPGA
What is the problem Please help me
There qre some attachement
Images are not clear can you reattach the images. If possible attach the project too.
What do you mean?
Eclipse results are from FPGA only, If it works on eclipse console than it means FPGA is working fine.
Elaborate the steps and you c/c++ code?
Anand Raj Shankar
Hello
I cant thank you enough for your help.
I am tying to do an application like a timer so I need to use the seven segment that s why I begin with using the counter binary
and it worked in console. the code runing in the console of eclipse but is not in my card.maybe because I dont have to use lcd .
this is my project.there are some photos but I dont know how can I send all my project.
but the code is the binary count of library, qsys and console there are attachement .
pleaaaase help me
I try to simplify my code just for seven segment but nothing happen in my board .
this is my code :
# include "count_binary.h"
/* Seven Segment Display PIO Functions
* sevenseg_set_hex() -- implements a hex digit map.
# ifdef SEVEN_SEG_PIO_BASE
static void sevenseg_set_hex(int hex)
static alt_u8 segments[16] = {
0x81, 0xCF, 0x92, 0x86, 0xCC, 0xA4, 0xA0, 0x8F, 0x80, 0x84, /* 0-9 */
0x88, 0xE0, 0xF2, 0xC2, 0xB0, 0xB8 }; /* a-f */
unsigned int data = segments[hex & 15] | (segments[(hex >> 4) & 15] << 8);
IOWR_ALTERA_AVALON_PIO_DATA(SEVEN_SEG_PIO_BASE, data);
# endif
/* static void count_sevenseg()
* Display value of 'count' on the Seven Segment Display
sevenseg_set_hex(count);
# endif
int main(void){
int __attribute__ ((unused)) wait_time; /* Attribute suppresses "var set but not used" warning. */
int count = 0;
/* Continue 0-ff counting loop. */
while( 1 )
usleep(100000);
count_sevenseg();
* If done counting, wait about 7 seconds...
* detect button presses while waiting.
if( count == 0xff )
printf("\nWaiting...");
usleep(100000); /* Sleep for 0.1s. */
count++;
return 0 ;
