21615 Discussions
Nios2-elf-gcc assembly code parser
Hey all...
I want to find out if somebody have done some work on parsing Nios II assembler files... These files can be created by the -S option of the nios2-elf-gcc executable.
Thank you for your time
you can also use objdump utility to dissassemble existing elf file, like this:
nios2-elf-objdump.exe -d some_file.elf
it is usefull for manually filling the programming ROM that nios will read to execute your program or manually injecting SEU. however I don't see any other use in it.
