I just bought a DE2 board and installed the software it came with. However, when I follow the tutorial to make a "Hello World" program using the Nios2 IDE I get an error message saying that the .elf file was not generated. I have made sure that I am following the tutorial steps exactly but I always get the same error. Any advice is appreciated.連結已複製
4 回應
I'm also using a DE2 board and I came across two problems when I was following the "Hello World" tutorial: 1) My PC has Windows 7 installed, so every time I use the "Nios 2 Software Build Tools for Eclipse" I must open it by right clicking it's icon and selecting "run as administrator". 2) Last time I checked this tutorial, It advised to allocate only 20KB of internal SRAM memory for the Nios 2 processor. However, the "Hello World Application from template" requires more memory than that! So I had to switch to the "Hello World Small Application from template" to make it work. I don't know if this applies to you, but it is worth the shot. Thomas.
