21611 Discussions
No internet access through Ethernet with Linux Kernel 4.14
dbhag2
I am upgrading my custom board which is using the Cyclone V socfpga from linux 3.10 to 4.14 and I am having difficulties in getting it connected to the internet.
I our emac setup is as explained in this link https://rocketboards.org/foswiki/Projects/CycloneVRGMIIExampleDesign
Here is the bootup message log: https://0bin.net/paste/GZOOq7cPgc37X9KG#z0XrAOy3Eiia1Kpz6NmD1K920EHnbV3u1KUsVM8WRT-
and our device tree: https://0bin.net/paste/cijoyBcQ0KUfidW8#M9L9pR8MvpyXhqxRuDCqe-QOaQNcHH4kIajcz0v6Gm1
The driver seems to be loaded correctly and the PHY is detected.
I would be really grateful if someone could point me in what could be the issue here. I have been struggling with this for months!
Thank you and Kind Regards,
Deva
FawazJ_Altera
May I know what is the output of ifconfig command from on your board?
Thank you
dbhag2
Hi FJumaah,
Thank you for your answer!
Here is the output of ifconfig
# ifconfig eth0 Link encap:Ethernet HWaddr 22:66:2F:0B:67:3B UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:78 errors:0 dropped:0 overruns:0 frame:0 TX packets:5 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:11408 (11.1 KiB) TX bytes:1710 (1.6 KiB) Interrupt:29 Base address:0x2000   lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
If I use the command "ifconfig down" my board instantly reboots!
FawazJ_Altera
It seems driver issue.
Can you set an IP to your ethernet port?
ifconfig up eth0 192.168.XXX.XXX
Let me know the ifconfig ouput and ping output after you set the IP.
Thank you
