Hello
Please guide me why I don't see any logic element for the current code : LIBRARY ieee; USE ieee.std_logic_1164.all; Use ieee.numeric_std.all; USE work.my_data_types.all; -- to define array of input ( package ) ENTITY test IS PORT ( clk: in std_logic; OutResult: out signed(9 downto 0)); end test; Architecture behave of test is Signal Im : Array2D:=(("0010000111","0001111110","0001001101","0000000000","0000000000"), ("0001001111","0010000100","0000101100","0000011011","0000000000"), ("0001011101","0010000100","0000100111","0000101001","0000000000"), ("0001011101","0010000100","0000100111","0000101001","0000000000"), ("0000000000","0000000000","0000000000","0000000000","0000000000")); signal Bufftemp:Array2D; signal Buffsig:signed(9 DOWNTO 0); begin Process (clk) variable i,j:integer range 0 to 7:=0; begin if (clk' event and clk='1') then for j in 0 to 1 loop for i in 0 to 1 loop Bufftemp(2*j,2*i+1)<= Im(2*j,2*i+1) - 5; end loop; end loop; end if; Buffsig<=Bufftemp(i,j); end process; OutResult<=Buffsig; end behave;Link Copied
- « Previous
- 1
- 2
- Next »
--- Quote Start --- Initially, you may do better using the mega wizard to generate the ram, then you know for sure that a ram will be used. Infered ram has to match the correct behavioural template to be correctly inferred, otherwise logic will be inferred. Review this document for coding styles: https://people.ece.cornell.edu/land/courses/ece5760/de1_soc/hdl_style_qts_qii51007.pdf --- Quote End --- I didn't call memory using mega wizard before , so I will read the document carefully and try it. I am really thankful to you. You are really helping me.
--- Quote Start --- Initially, you may do better using the mega wizard to generate the ram, then you know for sure that a ram will be used. Infered ram has to match the correct behavioural template to be correctly inferred, otherwise logic will be inferred. Review this document for coding styles: https://people.ece.cornell.edu/land/courses/ece5760/de1_soc/hdl_style_qts_qii51007.pdf --- Quote End --- Dear Admin, I have created a memory ( but without wizard) and read it as follows PROCESS (clock) variable i:integer range -1 to 31:=-1; BEGIN IF rising_edge(clock) THEN i:=i+1; q1 <= ram1(i); -- output ( ram is mif file of 32 element, each of 3 bits) END IF; END PROCESS; ram1 is external file that I successfully read its data , each element read in one clock cycle. However , I am trying to get the first three elements after they read to apply a mathematical equation to them in next clock cycle. when I tried to create registers to carry the values , I unintentionally read three element at the same time so the memory transferred to logic elements. My question is , How can I store only three elements and add them and then I get another three to add while keep reading? I tried to postponed in this way but am not sure if its true BEGIN IF rising_edge(clock) THEN i:=i+1; reg1 <= ram1(i); reg2<=reg1; reg3<=reg2; q1<=reg3;
I highly suggest reading how memory works. You can only access 1 address per clock cycle. So if you really want to access 3 elements to add them, you will have to read them out over 3 clock cycles. You could pipeline the design to do the adds to minimise total latency.
I highly suggest using the megawizard ram, as this would become obvious.- Mark as New
--- Quote Start --- I highly suggest reading how memory works. You can only access 1 address per clock cycle. So if you really want to access 3 elements to add them, you will have to read them out over 3 clock cycles. You could pipeline the design to do the adds to minimise total latency. I highly suggest using the megawizard ram, as this would become obvious. --- Quote End --- When I create a wizard I don't see how to connect it with my vhdl code in Pedroni book or in the document you sent me. Also, I wonder if this way of reading in three clock cycles is efficient way IF rising_edge(clock) THEN i:=i+1; reg1 <= ram1(i); reg2<=reg1; reg3<=reg2; q1<=reg3; Or you suggest me better one? Thanks alot
Your code still suggests you think you're writing software. You are not. You need to understand how the hardware works before you should be writing the code - hence why I suggest drawing a diagram.
I suggest reading how the ram works from here: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ram.pdf- Mark as New
--- Quote Start --- Your code still suggests you think you're writing software. You are not. You need to understand how the hardware works before you should be writing the code - hence why I suggest drawing a diagram. I suggest reading how the ram works from here: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ram.pdf --- Quote End --- Ok. I will . Thank you.
- « Previous
- 1
- 2
- Next »
