21615 Discussions
Node instance "tcm_address_w_check" instantiates undefined entity
Hello.
I am using Quartus 13.1 and Qsys.
I can build my project using verilog, qsys and NIOS previously.
But I added the clock component at pll in qsys.
I had error at build of quartus (using verilog):
Error is "Node instance "tcm_address_w_check" instantiates undefined entity"
I can generate qsys whih have no error.
But building quartus had error.
I checked system contents in qsys, I can not find tcm_address.
I am appreciate, if you suggest this issue.
Check into the design hierarchy where it is being instantiated. You can trace the error in analysis&synthesis messages sequence.
"But I added the clock component at pll in qsys."
Mind further elaborate on what does it referred to by adding clock at PLL?
Thank you for responding.
I used Avalon_ATTPLL.
I used Edit. At Output/Clock tab, I set c3 and c4 clock data.
And I build the connection to dualport RAM at system components in qsys.
