I following the hello world example in soc eds guide, however when I try to debug the example, I got a strange issue pop up , "ds_debugger_cmsisdap", even I reinstall the USB-Blaster , it still never work,. any tips here?
this item is something to do with the usb- blaster feature, what license type that you are using now?
Oh, I am using the free evaluation version 30 days! is this not supported for DS-5 debug?
It just failed to connect. below is the complete note:-
Unable to connect to Altera-SoCFPGA-HardwareLib-GNU-Debug. Failed to connect to the device The desired vendor daemon is down. Check the lmgrd log file, or try lmreread. Feature: ds_debugger_cmsisdap Vendor:Host: trc-cgy-wap1 License path: /home/p1215579/Téléchargements/license.dat:1800@trc-cgy-wap1: FLEXnet Licensing error:-97,121 For further information, refer to the FLEXnet Licensing documentation, available at "www.flexerasoftware.com".- Mark as New
Here is the more detail
Unable to connect to Altera-SoCFPGA-HardwareLib-GNU-Debug. Failed to connect to the device The desired vendor daemon is down. Check the lmgrd log file, or try lmreread. Feature: ds_debugger_cmsisdap- Mark as New
all licence include the community allow for normal DS-5 debug..there is no such restriction. could you try reapply for license and reinstall again?
I got another copy of evaluation license and reinstall this, i still having the same problem !
who can help me. !- Mark as New
by the way, how and where did you get the evaluation license?
I say your license is not on line acquired, maybe if you can have a try to regenerate from this side.
http://ds.arm.com/altera/altera-eval-edition/ You can always kepe your exiting license, and add another one from here. I suspect the current license did not cover the Altera usb-blaster related drivers- Mark as New
I got my license dat from the sales, but no idea where is thins created from . Nut no issue already as after i got a new license from altera-eval-edition.. it works well..
so you are using the new license it works, some how maybe license you got is been wrongly generated without the access of the usb blaster driver. good to hear that.
I also found something quite related with your issue, maybe also the same .
http://community.arm.com/message/4034
