21611 Discussions
On-Chip termination in Cyclone IV FPGA to interface it with the SDRAM
Hi All,
I am dealing with the pin assignments specifications for Altera's Cyclone IV FPGA.
I am using Altera's Quartus II software and using its QSYS tool I have designed a system
to interface DDR2 SDRAM with FPGA. While I was assigning pin assignments to
FPGA. I came across the feature - on-chip termination, which fascinated me as it
can deduct the requirement of adding pull-up resistors and can reduce the bulkiness of the
board.
As all the pins from FPGA to SDRAM are output or bi-directional, I have applied
output termination with series 50 ohms with calibration to all the pins. My questions are-
1.is my decision of applying output termination, with series 50 ohms calibration,
to bi-directional pins correct?
(I have read that
For input pins, input termination should be used with parallel resistors
For output pins output termination should be used with series resistors
For bi-directional both the input and output termination or dynamic
termination should be used.
But in Cyclone IV input termination and dynamic termination options are not
available. These options are there in Stratix family FPGAs)
2. If output termination with series 5o ohm with calibration is correct, do i need
to add any external resistors for termination on fpga side?(Except RUP and RDN
resistors)
Please don't misguide me if you are not sure about your answer. It may cause a very big trouble to my PCB department. It's better that you give some references so that I can clear some things in my mind about OCT. Thank you.
Ashish Devre
