Hi
Who know the reason? When i test the PCIe example(create by pcie hard ip), you can find it in <your project dir>\PCI_examples\chaining_dma. You program it in FPGA, Then test it with WINDRIVER. first you wirte 0x11111111 to offset 0 in BAR0(for example), then you read the same address. you can get 0x11111111. But, after some minutes, what you read is 0x00000083 or 63. who know the reason?Link Copied
