21607 Discussions
PCIe simulation guideline
I am using PCIe hard IP in cyclone-V device with eight MSI to GIC generator IP to give interrupt sequence to HPS in Qsys. Please help me to guide with step by step that how simulate this design in modelsim 10.1?
Hi ,
when you want to use PCIe hard ip for cyclone v you can just generate in qsys the simulation files for it. Then look into the file avmm_bfm_driver , there is some example code within. You also should have a look into the user guide. There is everything expained what you need!
Kr,
Florian
