21616 Discussions
PLL Phase Shifting design
The purpose of this design is to allow the phase bumping of a PLL as specified in AN367: Implementing PLL Reconfiguration in Stratix II Devices http://www.altera.com/literature/an/an367.pdf. The major differences being:
- This design only allows for phase bumping of the PLL as described on pages 8-11 of AN367
- This design does not require the use of the altpll_reconfig megafunction as described in AN367, just a simple register interface
- This design only uses logic for storage of the PLL configuration bits (< 20 registers and 40 ALUTs); no RAMs or ROMs are used
Can you add the design files (.qar, .v) and the .pl script?
SLabe
Partner
Hello, where can we find the files referenced in the posted Word Document? Thank you!
