PLL clock output
My design needs the PLL-clock output to be mapped to non-dedicated clock output pin of FPGA. When I do so, the following error message appears.
What would be the best solution?
Warning: PLL "pll_312M:u_pll_312M|altpll:altpll_component|pll_312M_altpll:auto_generated|pll1" output port clk[1] feeds output pin "PLL_OUTCLKP~output" via non-dedicated routing -- jitter performance depends on switching rate of other design elements. Use PLL dedicated clock outputs to ensure jitter performance
It's not an error - it's a warning which you are guaranteed to get when driving non-dedicated pin with PLL output. If this is what you intended to do, you can simply ignore this warning.
Yeah, It was warning message only. Is there any option like inserting clock buffers as in Xilinx ??!!!
There's a clock control megafunction ALTCLKCTRL: http://www.altera.com/literature/ug/ug_altclock.pdf
PLL's outputs are already connected to global clock networks, so you don't need to implement any additional buffers.
