Hi!
I have a problem in realizing a PLL. I need a PLL that (with a 50 MHz in input) gives me 3 different clocks: CKSYS,CKPBWR,PCLK. The first have no shift from the clock source. CKPBWR must be NOT(CKSYS). The last one have a frequency of an half of clock source (25 Mhz). All this three clocks are used internally, they don't drive any output pin of the FPGA(DE1 Board). I have tried to realize it with MegaWizard pug-in manager but I have more than one timings problem. This is the quartus warning: PLL cross checking found inconsistent PLL clock settings: Warning: Clock: SYSCKSGen:SYSCKSGEN0|PLLSYS:PLLSYS0|altpll:altpll_component|_clk1 was found on node: SYSCKSGEN0|PLLSYS0|altpll_component|pll|clk[1] with settings that do not match the following PLL specifications: Warning: -phase (expected: 180.00, found: 414.00) Warning: Clock: SYSCKSGen:SYSCKSGEN0|PLLSYS:PLLSYS0|altpll:altpll_component|_clk2 was found on node: SYSCKSGEN0|PLLSYS0|altpll_component|pll|clk[2] with settings that do not match the following PLL specifications: Warning: -phase (expected: 0.00, found: 27.00) I have attached the PLL source code generated by altera plug-in any suggestions?Link Copied
those are TimeQuest messages, IIRC. The constraints in the .SDC file don't match the settings in your PLL compoment. You need to 1. constrain the input clock with "create_clock". 2. use "derive_pll_clocks" to constrain the PLL outputs- Mark as New
I have the same problem (same warnings), but what I found is:
After a compilation with Design Space Explorer I modified the phase of two generated clocks in two PLLs. Then I ran Analysis&Synthesis and the Fitter, started TimeQuest and generated a new .sdc-File with my own .sdc-File-Template. My Template defines all clocks in the design and derives the generated clocks (well it did before the compilation with DSE). But now the TimeQuest Analyzer generates me a .sdc-File with the old Values of the PLLs. And when I modify the generated clocks to match the implemented PLLs, Quartus only tells me that Warning. (With expected: <old value>, found: <new value>) Any Idea?
