PLL synchronizer
In my design I'm using 10MHz external clock. several (not all of them) blocks inside the code are needed 50MHz clock. In order to do that I created PLL from 10MHz to 50MHz and distribute to the relevant blocks.
Do I need to use synchronizer between the 50MHz output ports to the main 10MHz signals/ ports? If I do, is one synchronizer stage will be enough?
Idan
Hello!
Can you please tell me how did you create a PLL from 10MHz to 50Mhz?
I'm new to working with FPGAs and I'm finding it difficult to work with PLLs!
Thanks!
