Package data
I need some pad dimension of the package. I could not find it anywhere on Altera site. Can you help?
STRATIX II EP2S180 1508 pin and CYCLONE III 484 pin EP3CLS200F484.
What is the pad configuration?
Is it solder mask defined pad?
If so, what is Cu pad size underneath solder mask?
--- Quote Start ---
--- Quote End ---
On the Altera web site Support-> Devices then near the bottom of the page Packaging and Board Design.
There are package drawings in there.
Nial
Thanks Nial,
The drawing contain only ball diameter not pad diameter and nor copper diameter (solder mask define pad).
Gil
--- Quote Start ---
Nial
--- Quote End ---
