Guys,
I just ran into a switch-case where you can "case" on non-constant values. For example:
module silly(input clk,
input key,
output is_match,
output data_out);
reg data;
reg m;
reg d;
always @ (posedge clk)
begin
case (key) // synthesis parallel_case full_case
data:
begin
m <= 1'b1;
d <= data;
end
data:
begin
m <= 1'b1;
d <= data;
end
default:
begin
m <= 1'b0;
d <= 4'b0000;
end
endcase
end
assign is_match = m;
assign data_out = d;
endmodule
I know people use something like that for "one hot" state machine, but there "case" values are 1 bit wide. I am wondering if you can do that on, say, 32-bit wide data. It seems for me like an easy way to implement a search given that all data is stored in registers and every "word" is unique. Is that something that would work in real-life? Or am I being fooled by syntax?
There are clearer ways to write the simple compare performed in this code.
The usage of parallel_case seems confusing, because the second case statement is actually overwriting the results of the first. So it's effectively just an inverted priority, no use for this attributes. In addition, I would follow IEEE 1364.1 (Standard for Verilog RTL synthesis) that opts against usage of th full- and parallel_case attributes in synthesized Verilog.
Topic Options
